| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
It would be useful to have something similar to C#'s LINQ in LabVIEW. Basically a way to "query" array of clusters/objects (and for some nodes even array of strings/numbers/whatever) without needing to use loops. I imagine nodes similar to invoke nodes, something like the below examples:
If one wired an array of clusters one should be able to choose from the elements in the cluster, like an Unbundle By Name node. For the Where node one should subsequently be able to select how to filter based on the data type of the selected element. For example: Equals, Greater Than, Less Than, Greater or Equal to, In Range, etc. for numbers. Equals, Contains, Starts With, Ends With, etc. for strings.
