10 | |
3 | |
2 | |
2 | |
2 |
Unlike the other growable functions (eg Build Array, Concatenate Strings), the output of the really appreciated new Merge Errors function shouldn't be centered to avoid a bend in the error wire.
Re-opening this idea due to the discontinuation of LabVIEW NXG.
