shb
LVCompare.exe can compare VIs with the same name
Status: New
When LVCompare.exe is called with two VIs with the same name an error is shown. Instead it could copy one of the VIs to a different name or open one in a new Project. This would make live with some Version Control tools easier.
It is probably the same with LVmerge.exe
Greetings,
shb
4 Comments
TCPlomp
Trusted Enthusiast
This is indeed a limiting issue when using LVCompare with an external SCC. To my knowledge all SCC tools that provide a merge function present different filename for each 'base' file.
My LabVIEW Ideas
Elijah_K
Active Participant
I recommend using SCC to call LVCompare.exe, which will rename the files for you when you invoke a diff operation.  More info
Elijah Kerry
NI Director, Software Community
shb
Active Participant
Active Participant
I use an SCC, but Mercurial does not rename the file but place it in a different folder.
MGWhittaker
13 years later... this is still an issue. I can't use LVCompare.exe with TortoiseHG (Mercurial) for that reason.
