6 | |
6 | |
3 | |
2 | |
2 |
When running LVCompare from the command-line (i.e. from my Tortoise SVN shell) it will try to open the compare tool in the last context which was active. Unfortunately, the code required does not run in RT or FPGA contexts.
I would propose that LVCompare, when called int his way, should ALWAYS run in "My Computer" Context. Or even better, in a context all of its own (new Project).
