3 | |
3 | |
2 | |
2 | |
2 |
My team has been working with LVMerge.exe for a while. I wish to disable "auto-resolve" as a default, instead of unchecking it after loading. Disabling block diagram cosmetic changes would also be nice. Some method to modify these settings, so that on the next VI load, the modified settings would be used instead. My original post is here.
Mike
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
