MichaelBalzer
LabVIEW 2016 Structure Resize to Show Previous Structure Size
Status: New
The real-time updating of the block diagram when dragging the borders of a structure is a nice feature, though there's one thing I noticed was lacking compared to previous versions of LabVIEW - some sort of indicator of the structure's original size during a resize operation.
For example I begin a resize operation in LV2015, and get a dotted border of the new structure size, while the original structure is visible. I can see the previous and current state of play in one move. With the LV2016 resize I can see the current state of things, but not what the structure size was. I propose adding an indicator to show the original structure size during a resize operation in LV2016.
Why is this useful? I find it helps better visualise spatial relationships between items on the block diagram during a resize (how much room do I need to make inside the loop to fit three more VIs?). It is also a hint as to what cancelling the resize operation will revert the block diagram back to.
It need not be a dotted box if that's confusing with older versions of LabVIEW. Perhaps a semi-transparent / greyed out version of the structure? Or perhaps a dotted line drawn between the old handle position and the new (similar the ctrl+mouse drag when inserting space).
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
