10 | |
3 | |
2 | |
2 | |
2 |
I'm surprised a search did not turn up anything about this. NI should create a LabVIEW Amazon Web Services/Azure/Docker Image(s). The sample case I am thinking of is having a Jenkins CI server running on AWS EC2 with a full LabVIEW environment installed. This would allow off-loading the long FPGA or full RF suite builds during CI.
Apparently NI had this with LabVIEW 2012 on AWS
I would suggest to NI the following steps:
Thanks!
Charlie
