6 | |
5 | |
3 | |
2 | |
2 |
When I diff a VI, I am usually interested in the change in semantics or syntax, not the cosmetics. I usually don't care about moved wires and tunnels and stuff like that.
The critical word in here is "usually". Because there are cases when I might be interested in these changes, too.
We all know the command-line options like "-nobdcosm" and "-nofppos". But these require closing LV-Compare and restarting it. And they assume my RCS-frontend allows me to specify multiple command-lines for diffing the same filetype, which is not true for the one I use (TortoiseSVN).
So I would like to have a way of toggeling these (and the other command-line options) from within the LV-Compare window. Create checkboxes or fold them into a context-menu, there are many ways of implementing, either one will do.
Of course the user would have to update the list of differences after toggeling one of these options, but hey: the "Update" button is already there 🙂
