Can we cause an error if there are coercion dots on the block diagrams for FPGA targets?
This would be helpful for finding wrongly connected fixed size arrays especially at the interface of a subVI - the coercion dots are easy to miss but usually mean something is seriously wrong!
This could be a setting in the "Tools | Options | Block Diagram" dialog.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
