| User | Kudos |
| 14 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Provide a new command line option to show the block diagram of a VI in addition to and above the front panel automatically. I almost always open VIs in my project folder from a terminal and most research and development work is on the code. See current arguments here: https://www.ni.com/docs/en-US/bundle/labview/page/labview-defined-command-line-arguments.html
