| User | Kudos |
| 9 | |
| 9 | |
| 4 | |
| 4 | |
| 4 |
Hi all,
I would like to suggest any labview program that uses simple codes (which doesn't use rio, dac and all) should be given inbuilt options to be converted as a .apk file for android systems. so the mobile's Bluetooth or wireless networks should be able to utilize the code without the aid of computer system.
Actually I developed a code for getting data over WiFi and process it through labview, if it can be converted into an application file that can be used in mobile phones means i can further enhance its use for my graduation project. Please let me know if there are possibilities.
Premkumar.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/LabVIEW-module-for-Android-and-iOS/idi-p/1437506
