| User | Kudos |
| 11 | |
| 10 | |
| 10 | |
| 5 | |
| 4 |
The Arduino Due is a 32 bit ARM based microcontroller board that is destined to be very popular. It would be great if we could programme it in LabVIEW. This product could leverage off the already available LabVIEW Embedded for ARM and the LabVIEW Microcontroller SDK.
The Arduino Due is currently in developer trials and is due out later this year. It is expected to be about $50 and is open hardware. The ARM chip is an Atmel SAM3X8E ARM Cortex M3 running at 84 MHz resulting in 100 MIPS of performance. By way of comparison, the current LabVIEW Embedded for ARM Tier 1 (out-of-the-box experience) boards have only 60 MIPS of processing power.
The Arduino brand has an enormous following and Google has selected the Arduino Due for their recently introduced (28 June 2012) Accessory Development Kit for Android mobile phones and tablets (the ADK2012).
(By the way, the currently-available LabVIEW Arduino toolkit does not target the Arduino (and couldn’t since the Arduino Uno uses only an 8 bit microcontroller). Instead there is fixed C code running on the Arduino to transfer peripheral information to the serial port and back. That is, none of the LabVIEW target code executes on the Arduino. This idea is for LabVIEW code developed on a desktop to be transferred and execute on the target Arduino Due.)
Wouldn’t it be great to programme the Arduino Due in LabVIEW?
Available in LabVIEW 2020 Community Edition and later. The Community Edition includes the LINX Toolkit, which provides support for programming Arduino devices. Only the Arduino Uno was officially tested, but other Arduino devices may work as well.
