2 | |
2 | |
2 | |
2 | |
1 |
All VIs should have a BIG “Run” arrow.
The “Run” arrow is the button that is used the most on the Front Panel of any VI. Hence, it should be easier to click (by being bigger) than “Run Continuously “, “Abort” or “Pause”, which are the same size but much more rarely used.
Because it takes me 1 or 2 seconds to find and click the “Run” arrow, I always use the <Ctrl-R> shortcut. However, through teaching LabVIEW courses and LabVIEW Hands-on sessions, I noticed that even users with several months if not years experience in LabVIEW are unaware of the shortcut and use the “Run” arrow instead.
Making the button bigger would save a second or so each time we run a VI, which makes LabVIEW that bit more user-friendly.
(I am sure the UI R&D folks can make the arrow look better than in the image above.)
Best Regards,
Petru
