It would be good to be able to add labels to each sequence local. I know you can add comment boxes but of course these do not move with the sequence local. I find that I have to switch between the stacked frames several times checking to see which line is which before i can wire it up
. I've added a picture to show what it looks like commented and what it could look like with labels. I wondered if the labels could be type based colour coded like other items and it would be pretty usefuil if the labels had some indication of which sequence frame was driving them e.g. Fr3/Fr9.
