I started to use Labview Web Service and I have a couple of suggestions
In the Startup Vis you are able to monitor the status of the web service, but you are not able to close it. It says that labview will automatically close the Labview Web Service when closing a standalone exe, but there are some schenarios where you might want to close programatically the web service. e.g.:
- When building a standalone exe and you want to be able to close the service programatically.
Also,
As soon as the web service receives a URI that doesn't have a Web Resource, it throws an error without been able to handle it. Been able to handle the error could be beneficial when trying to make a dynamic routing system e.g. Many web frameworks.
BR
