2 | |
2 | |
2 | |
2 | |
1 |
Would like to target Labview embedded on a host of platforms. Specifically x86, lynuxworks, Vxworks and xilinx platforms - boards, SBCs, COMs, stacks, PC/104... Like PXI, the way to get the users onboard is to show that the industry supports this direction and you are not tied to one vendor. It would be expensive if in an iterative learning process (necessary but collaboration is also necessary with well established & matured platforms/standards) the users one chosen platform vanishes (maybe like fieldpoint?). Packaging options is also very important to achieve something like Adlink's MilSystem 800 that the application demands.
Pavan Bathla
