11 | |
11 | |
3 | |
3 | |
2 |
When working on a queued statemachine today, I realized its difficult to keep the wires straight. Usually you want one error wire going through your queue functions and into your subVIs but lining them up to keep the error wire straight often causes wires connected to the top connection terminal to get in each others way. If the queue functions icons were taller, this problem would be eliminated. See attached pictures
