James_McN
Launch Unit Test from Results Window
Status: New
Naturally, the first thing you want to do when a unit fails is go to the test definition to understand why it has failed.
I propose that you should be able to double-click the test name or even better the failed test case to launch the .lvtest definition directly from the results window.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
