11 | |
10 | |
3 | |
3 | |
2 |
I'm not sure how LV populates the tree under Options -> Menu Shortcuts, but I've been longing now for to long te be able to have some SCC actions (most important checkin/checkout) under a shortcut key. Same for several add-ons in that settle under the Tools menu, a couple of them I would like to have accessable via a shortcut key.
So the idea is simply to make everything in the menu available for configuring a shortcut for it.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
