6 | |
6 | |
3 | |
2 | |
2 |
The description of a control does does not wrap. The context help window tries to accommodate to the description but there is an upper limit of its width; if the lines of the description do not fit, the context help window displays a horizontal scroll bar, which makes the description hard to read.
Not an idea post
