Default selection mode is "1 item" - the terminal is a single I32.
Changing the selection mode to "1 or More Items" changes the terminal to 1D array (of I32).
Now, changing it back to "1 item" leaves the terminal as 1D array, which does not match the current selection mode.
In this case, a redundant Index Array should be used.
I suggest that the listbox terminal will always match the selection mode, and will change accordingly.
(Why not replacing the listbox with a new one? because you lose all your custom settings.)
Amir.
