| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 5 | |
| 4 |
Whenever I'm working on let's say a state machine I find that I need to resize the case structure now and then. Mostly make it larger, then I clean up my code and want to make it smaller again. Often when I do this, the constants (usually) pointing out the next case either get longer wires since they get further away from the border (when making the structure larger), become hidden (structure made smaller and no auto-grow) or prevent the resize (auto-grow enabled).
A solution to this would be to be able to lock BD objects with respect to the nearest corner of an owning structure, in the same way the loop index terminal is locked wrt to the corner of a for or while loop.
