Very often I use the transparency portion of an icon to make tiny icons (1/4 height) that are useful for not taking up too much space. Only problem is to do this one must delete / hide other layers of the icon. It would be nice if the VI remembered that I deleted / hid the layers, so that if I apply the library icon template to all VI's in the library, it does not convert my icons back to full size icons.
