| User | Kudos |
| 5 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
Hello all,
What Happens
When I move my project hierarchies to different directories on disk, often I notice that build specs lose most of their configuration.
Why?
I've theorized that this may be due to references to absolute paths, but when I look in the XML of the .lvproj file, this doesn't seem to be the case. My other theory is that it has something to do with auto-populating folders, which I use extensively. (Maybe I shouldn't?)
Is there some practice that I should be avoiding? Nonetheless, I'd appreciate it if this were fixed.
More Context
I use source control in my everyday development. (Peforce, in case you're curious) I notice that when I switch workspaces on different PCs or a different developer uses another location on disk, I often have to reconstruct build specs by hand. It's really annoying, especially because there's no easy way to export or import a build spec.
Has anyone else experienced this? If so, please vote for this idea.
