13 | |
11 | |
3 | |
3 | |
3 |
I don't know how many times I've added a case statement post-programming, but I do know that there isn't an easy way to make a tunnel the case selector. Usually I delete the tunnel and then drag the case selector down and then rewire, there should be an easier way. For loops and while loops have an easy way to index/unindex or replace with shift register, why can't a case statement be the same?
Implemented in LabVIEW 2014
