I am a big fan of the DVR and LVOOP. Consequently, I use lots of DVR's in my class data. The problem is that if you configure the DVR reference to show the type control, and right-click the type control, you get a truncated shortcut menu. The controls can also not be operated. This is especially painful if your DVR is a cluster with lots of enums that have to be edited often. One solution is to make the DVR type a typedef and use the control editor. But since the class data is a typedef of sorts, this method amounts to creating a typedef for your typedef, so to speak. You can also use "customize control" from the edit menu to fire up the control editor and apply changes without saving the custom control. But you can't check your work because you can't operate the control. Another solution is to temporarily copy the enum out of the DVR edit it, and cut and paste it back in over the original. However, it really would be better if type controls are fully editable/operable when shown.
Currently, type controls show a reduced shortcut menu when right-clicked, and the control cannot be operated
It would be better if controls inside typed references could be properly edited and operated ![]()
