| User | Kudos |
| 11 | |
| 7 | |
| 7 | |
| 5 | |
| 4 |
Given the properties dialog box isn't resizable, and there's nothing under the table (apart from one tick box), could you make the items table longer? It's really annoying when there are a few extra values that can't be seen because the table is too small.
Proposal to make the Edit Items box longer
