Make Invoke Node's Required Input(s) (text) as Bold (in the Node, and also in the Context Help & Detailed Help), like that of the Required Terminals of s SubVI are displayed in the Context Help window. ![]()
Currently, it is not helping much from a beginner's standpoint, to understand where the error in the VI is. ![]()
Also, the Detailed Help contents are misleading, wherein the Outputs are also termed as 'Required', which it totally wrong.
Fix this as well.
