Nandagopal
Make Tip strip of controls & Indicator to empty (default) when copied
Status: Declined
Now when we copy & paste a control/Indicator, It Tip strip is also copied to the new control/Indicator. It will be good if the Tip strip is made empty if controls/Indicators are copied & pasted.
Nanda
5 Comments
RavensFan
Knight of NI
I don't like this idea.
If I'm copying a control, then I want all attributes of it to be copied, not just selected ones.  Otherwise it isn't truly a copy.
Suppose I do want the tip strip info to be copied, then what would I have to do, edit the properties of every copy of the control and type it back in?
Darin.K
Trusted Enthusiast
Sometimes there are differences between cut and paste and Ctrl-Drag copying, so there is a way to have it both ways. Personally, I am with RF and would expect this to be copied no matter what.
Nandagopal
Each and every controls/Indicators represent individual purpose which will be included in the tip strip and as a outlook(Aesthetic) they may be common.
JÞB
Knight of NI
I'm firmly in the "a copy of an object inherits all attributes" camp myself.  First because that is the expected behavior, second because I would need to remember what properties copied and what ones did not.  A long and confusing list that would have me swearing at the end of every daySmiley Frustrated
so please sirs and maams don't change the copy- paste or the ctrl+drag drop (I STILL get confused with the copy/paste and Ctrl+DnD differences on clones and vi server referances)
JordanG
NI Employee (retired)
Status changed to: Declined
