6 | |
2 | |
2 | |
1 | |
1 |
One of the things that sometimes bugs me when using LabVIEW is that if you have a front panel or block diagram in a small window, many of the menu options and toolbar options are inaccessible without having to resize the window first. You have to have a minimum window size to be able to access all of the toolbar functions.
Still don't get it?
This is how big I want my SubVI window to be:
Problems with the above:
To be able to access the entire toolbar, the windows has to be at least one of the following wide:
Why is this a problem?
Existing workarounds:
Proposed solution:
Please make it so that the menu and toolbar are accessible regardless of window size. One solution would be to have a button that allows you to 'scroll' the toolbar or have a pop-up dialogue that shows the missing toolbar buttons as per the image below.
MS Paint skills (icon lifted from Chrome's bookmarks bar):
As an aside, MS Word manages it fairly well (even though it isn't that readable), and it has a LOT of toolbar buttons:
Please consider my idea (or Kudos it) for future versions of LabVIEW - it will improve usability of the IDE.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-access-to-menus-on-the-menu-bar-without-re-sizi...
