muks
Make block diagram scroll realistic
Make both the vertical and horizontal scroll get enabled only when the diagram is not able to fit inside the screen.
15 Comments
AristosQueue (NI)
NI Employee (retired)
We do disable the scrollbars when your document is truly smaller than the window. We consider a certain whitespace border around your objects to be part of the document. The size of the whitespace border depends upon the size of your window... the larger the window, the larger the whitespace border. This whitespace border greatly facilitates adding additional code during development -- it provides visual feedback that the diagram (or panel) can be expanded in that direction, something that a disabled scrollbar does not indicate, leaving newer users very confused about how to expand available diagram space. Although the ideal is a diagram fits on a single screen, growing off screen in a single direction is often useful for a given VI.
I am NOT going to ask that this idea be closed. Even though the current design is deliberate and considered, if there is a groundswell of kudos, we would look at changing the behavior. As of right now, though, we believe this to be a valuable feature of LabVIEW's user experience. My intention in posting this is to make everyone aware of the value of this feature. It may be that you can suggest an idea that retains this value while also meeting the concern you have -- which I suspect is simply knowing whether or not you have code off screen. That may be something that we could indicate in another way rather than disabling the scrollbars, perhaps by annotating the scrollbars.
Wart
This bugs me as well, but if I need to drop a parallel while loop, then I need the ability to scroll vertically to draw it.
crossrulz
Knight of NI
The mouse wheel will still allow the scroll even though the scroll bars are disabled.  Not sure if this fact actually influences anything.
AristosQueue (NI)
crossrulz: it really doesn't. Discover-ability is part of the UI design. A disabled scrollbar does not give any feedback to a user that the scrollbar will do anything. It's like keyboard shortcuts that are not in the menus (like ctrl+click on the conpane to swap terminal connections) -- nice if you're an expert, but used by very few people because there's no way to discover the trick on your own short of reading copious documentation.
tst
Knight of NI Knight of NI
Knight of NI
It is. This is a regular annoyance, in both the FP and the BD. I don't have any good ideas which won't involve modifying the default behavior of controls other than what's already suggested here.
___________________
Try to take over the world!
SnowMule
Active Participant
Is there a way to twiddle this, like the auto-diagram cleanup tool? (LabVIEW.ini?)
Something experienced users can tweak to their preferences, while allowing useable defaults for n00bs?
muks
Proven Zealot
Ok then i personally feel the white space is a bit misleading.
muks
Proven Zealot
Maybe disabled is a wrong word i used. The idea is ultimately to give you a rough feel of how much offset you are with respect to coding in a single screen. When you want to extend the screen horizontally or vertically then the scroll bar can get activated .
AristosQueue (NI)
There is some work being done for 2016/17 that will address this. I'll make sure the developers are aware of this discussion.
muks
Proven Zealot
Means this is under development?
