Jeff-P
Make custom error code files part of a project
Status: New
I decided to dive into the world of custom error rings, andit is a clean way to implement customized errors throughout a project.
That being said, forcing the custom error file to be in the user.lib folder makes this feature quite a bit less useful for me. I am working on a project with source code control and multiple developers. Since the custom error code file is in user.lib, it is not in my source code repository, and is awkward to share between developers.
I propose that custom error codes should be a project level feature. 99% of the error codes I want to add are specific to a certain project, so I don't need them in other projects, however I do want them to distribute with my project. I understand how to distribute this with my built application, but during development it is not as easy to share.
I am proposing that the error code text editor should be in the Project menu, and the error code file should not be required to be in user.lib (allowing it to be stored in a repository and shared among developers easily).
6 Comments
manu.NET
Active Participant
sbus
Yeah. Just add a local error list the same way you add a globals.vi to a project. It would ONLY apply to that project and would travel with the source files.
HorseBattery_Stapleguy
I think this should be a feature.
I disagree with the idea of having a globals.vi for a project. I already do this to manage certain development time constants and while that's a nice workaround... that's what it is. A workaround. A dedicated solution for managing these sort of error or project constants that must be edited during development should be as simple, clean and quick as possible.
For example, the globals.vi solution is a lot less convenient in my opinion if you wish to add format level features like those provided by the error ring unless you start managing a polymorphic instance of sorts for the "error constant" vi itself. That's a lot more tedious and slower to manage in comparison to the ease of use that would be granted by the development environment itself.
You can of course, develop tools to create and manage these things so on and on. But again, that's something that should already be part of the development toolset.
Ajay_MV
Active Participant
I agree.. The error codes needs to be local to project and controllable via SCM
Ajay MV
mthheitor
Yes, we need different ways to manage the custom error codes
adamVL
Hey everyone,
Bumping an old thread, but this is a problem people definitely still run into. I thought I'd share what our team does for that.
You can get a VIPM package called BR Error Handling. It lets you keep the text file with your custom errors right inside your project folder.
Since the file is in the project, you can just commit it to Git or whatever SCM you're using. Everyone on the team gets the latest error codes when they pull, and you don't have to manually sync that file.
It also gets around that annoying thing where you have to restart LabVIEW just to add a new error.
Anyway, here's the link if you want to take a look (there are examples included): https://www.vipm.io/package/bender_robotics_error_handling/
