3 | |
3 | |
2 | |
2 | |
1 |
Situation
Large project, takes a long time to open and close.
Multiple developers working on it concurrently.
Other developer checks in changes I want to see.
Go to SCC and Get Latest.
Attempt to open vi/class other developer changed.
Result
A severe headache from banging my head against the wall while clicking through hundreds of dialog boxes first asking me if I want to revert each VI (with many identical dialog boxes asking me the same question for the same VI) and then going through the entire process again asking me if I'm sure I want to revert the changes.
Proposed Solution
Include a large bottle of aspirin with each licensed copy of Labview.
