13 | |
11 | |
3 | |
3 | |
2 |
Quick Drop is very useful, but when it comes to adding other VIs, it's too annoying.
You have to select the VIs you use often from tremendously long pull-down, and the order is completely messed up in Japanese version.
It would be nice to be able to select the desired VI from the list of icon you always use, or search by VI name.
