Yakov
Make it posible to find error codes in help.
Status: Declined
Just that: Make it posible to find error codes in help.
I can never find general list of error codes wigh their descriptions in the Labview Help.
11 Comments
crossrulz
Knight of NI
There is the Help->Explain Error menu item.
The real problem here is that you have different error codes for different modules inside of LabVIEW.  I imagine it could still be done.
StephenB
Active Participant
What would really be nice is if functions documented which error codes they could throw
Stephen B
crossrulz
Knight of NI
You mean like this idea: List every error code a function can give out!
AristosQueue (NI)
NI Employee (retired)
Yakov: There is no list because the list is open-ended and shifts depending upon what modules you have installed. If you want to see a list of the error codes, open up the *-errors.txt files that are on your disk. The ones in <labview>\resource\errors are the ones for LV core. The ones in <labview>\user.lib\errors are installed by third-party libraries. The ones in C:\Program Files\National Instruments\Shared\Errors\ are from hardware drivers. Collectively these define the error codes on your particular system.
Yakov
What I mean is, when I go to help to look up error codes I get this:
... and none of the topics give list of error codes of any kind.
I would like to see something like this:
and if I open the page:
... here we go. Error Codes!
So in Labview Help for "error codes" the topics should be:
General Error Codes
Networking Error Codes
DAQmx Error Codes
Vision Acquisition Error Codes
AristosQueue (NI)
That file is in the index.
AristosQueue (NI)
There is no list of errors from the other modules because when LV ships, we don't know those errors. Each module/toolkit (including from third-parties) can install additional errors. That's why if you want this information, I was pointing you toward the error code text files.
Darren
Proven Zealot
Perhaps the best solution here is a dynamically generated list of codes and descriptions based on what is present on the system. It seems like we could provide a Help menu option that runs a VI and generates a dynamic HTML page with that info.
Yakov, given what AristosQueue said about the dynamic nature of the errors.txt files on the system, would a separate tool to generate information about locally-installed errors be a viable solution?
JÞB
Knight of NI
Darren
"Perhaps the best solution here is a dynamically generated list of codes and descriptions based on what is present on the system. It seems like we could provide a Help menu option that runs a VI and generates a dynamic HTML page with that info."
You mean like the error ring (Perhaps searchable)
Whatever is going on behind the scenes in that select error dialog ALLREADY generates a dynamic list from whatever in installed- redirecting its output to a HTML file ought to be relatively painless (For me at least- maybe not for the developer) Unless.... Hmmm If you don't pick that up 8-Ball might, I like that idea
johnsold
Knight of NI
Darren and Jeff,
Given the dynamic nature of error messages, the concept of a VI to get them sounds useful. Even better would be a list specific to a VI named (or by refnum) as an input to the Get Error Messages VI.
Go for it, Jeff.
Lynn
