13 | |
11 | |
3 | |
3 | |
3 |
In short:
It should be possible to copy items between targets in the project window. This should be possible with right-click copy option, Ctrl+C/V - AND by Ctrl+Drag&Drop.
Background:
If you have multiple targets in the same project and you wish to have some VIs, virtual folders or other resources available under each of these targets (not just to keep things available and tidy, but to avoid recompilation) you cannot just copy them from the reference under a different target. You either have to MOVE them (not what you want to do) or add them again. And and in the case of virtual folders this can be a substantial repetition of work...
