1 | |
1 | |
1 | |
1 | |
1 |
I'm a bit surprised that I could not find this suggestion already...but hopefully then it's not just an oversight by me...:
In the Edit Events dialog you can only add events from one source at a time, it should be possible to select multiple sources and add the same single (OR multiple there as well) events from those sources in one go. The event source selection should filter the events-list so that only the events that are common for the selected sources are shown.
In pictures...you should be able to do what I have imagined(!) doing in the bottom picture here:
