13 | |
11 | |
3 | |
3 | |
3 |
For controls and indicators created through Block Diagram, the display of the Label in the BD can be made invisible by right clicking on it and select Visible items. I used to do this often when my diagram gets bigger and bigger.
Oops lot of mouse strokes.... Instead if by simply pressing delete key, if the label gets invisible, then it will be very good and easy..... Just a thought. Please comment on this.
