Ever tried to parallelize a loop?
You just have to place your mouse over what feels an approximately 1 pixel wide area on the left side of your loop and press the right mouse-button without moving the mouse. If there was no input or case terminal around a context menu opens that gives you access to the function you need.
Point anywhere else and the contect menu doesn't contain what you need.
The context menu entry could also show if the mouse hovers over any other parts of the loop as well to make the area easier to point at.
