Many advanced funtions in the optimization and fitting palettes allow the use of a "VI model" given as a strictly typed VI reference to be defined by the user. A great feature!
LabVIEW provides various templates containing the correct connector pattern. Here is a list of the templates I found:
in labview\vi.lib\gmath\NumericalOptimization:
ucno_objective function template.vit
LM model function and gradient.vit
Zero Finder f(x) 1D.vit
Zero Finder f(x) nD.vit
1D Evolutionary PDE Func Template.vit
2D Evolutionary PDE Func Template.vit
2D Stationary PDE Func Template.vit
ODE rhs.vit
Global Optimization_Objective Function.vit
DAE Radau 5th Order Func Template.vit
function_and_derivative_template.vit
function_template.vit
As you can see, the naming is quite inconsistent:
Since the extension fully defines them as templates, maybe the word "template" could be scrubbed from all the filenames, making things more uniform and consistent.
Idea Summary: remove the word "template" from all model template names that contain it.
