10 | |
3 | |
2 | |
2 | |
2 |
I use highly descriptive, i.e. LONG, filenames while going through developmental iterations. Most of us store files on network servers in very deep path structures.
The Open section displaying existing file names is just too short, about 37 characters. In a world where 128 character filenames are possible, and pathnames even longer, why can't this window be permanently or adjustably wide enough to display the entire filename? Even some kind of rollover display with the full path/filename would be good.
This isn't just a problem with LabView but throughout the industry.
The Getting Started Window is resizable in LabVIEW 2012 and later.
