One of the more annoying features (see also here) is the unzip operation after downloading a LabVIEW distribution. As a first step, it will unzip somewhere into the "National Instruments Downloads" folder.
Of course it will place the progress window right in the middle of your monitor. Typically this takes a while and actually want to do something else and move that window out of the way, so we can still watch it in the corner of the eye. Easier said than done! A simple click in the window header pauses the unzip operations and asks if I want to abort... NO!!! I simply want to move that window is the same way I can move any other window from any other application!!! Why that nonstandard behavior? Just to annoy us??? Here's what happen if I click anywhere near the top edge of the window:
When we righ-click the window header, we see two options "(1) move" and "(2) close". Why is close the default??? If we really want to close, the [x] button is right there another inch to the right and nobody should have trouble finding that spot. If I click elsewhere in the header, I most likely want to move that window!
In order to actually move it, I have to right-click the window header and select "move". That seems silly!
IDEA: The unzip window should should be less annoying and easy to move elsewhere. Thanks!
