13 | |
11 | |
3 | |
3 | |
3 |
When working with Maps and Sets with objects you have to specify the parent object or otherwise, you end up with broken wires - unlike arrays. Arrays will coerce the child objects to the parent, it would be helpful if maps and sets did likewise.
I have attached the project that you can use as a workbench.
Moved to CAR database: CAR 738357
