| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Currently, when you use context help and hover over a VI it shows terminals and a little snippet of what it does. I use this a lot. When using quick drop though, the context help doesnt dynamically change to each item selected or hovered over with the mouse. Its like this currently
I would like to see it so that when I hover over an item in the quick drop, the help page updates so I can read it without having to drop it onto my back panel, read, then delete and try again. Like this
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Context-Help-and-Quick-Drop/idi-p/942809
