13 | |
7 | |
3 | |
3 | |
3 |
The following code will essentially do what I want, but I want this to be natively incorporated into the IDE as an option.
90%+ of the VIs that I write have a front panel that doesn't get shown to the end user, and yet, whenever you open a VI what does it show you? The front panel. I think the default behavior of opening a VI should be to show the block diagram ONLY. This would have several advantages for the developer:
Ideally this would be an option in the Tools --> Options dialog (that I would always turn on).
This idea is similar to one posted almost 15 years ago, but I don't consider this a duplicate because this takes things a step further by not opening the FP at all.
