10 | |
3 | |
2 | |
2 | |
2 |
Custom probes are great, however unlike the default probes you do not always have them with you...so why not just make the default probes just a tad smarter?
- The array probe e.g. should not just show a single cell - it should by default show at least some of them (1*10 for 1D, 10*10 if 2D etc. e.g.), have it's scrollbars visible and be resizable?
You could add some core information about the array, like it's size e.g. in an indicator on the top as well....and perhaps have a pull-down menu for the display format. Keep it general and simple of course, but a bit more convenient than today's probe.
- The string probe should also be resizable and have a control that let's you switch the display format.
- etc.
Available in LabVIEW 2015 and later. Default probes resize (including showing more array elements) when the Probe Watch Window is resized.
