6 | |
2 | |
2 | |
1 | |
1 |
This drives me crazy... I've noticed that if I have some code on my block diagram (or controls on my front panel) the scroll bars indicate that there is more stuff outside the view of the window that can't be seen. It would be nice if the scroll bars only activated if there was actually code outside of the screen to be found. Every time I see this, my OCD kicks in and makes me try to move my diagram to show the hidden code, only to realize that LabVIEW is just messing with me...
Of course an image is worth 1024 words..
While I understand the desire here, the alternative is that without this "boundary", it is impossible to create more space without resizing the window, which is also undesirable. The behavior being exhibited is intentional by design.
