I can't find an easy way to edit the value a set constant on a block diagram or event a set control on a front panel.
Currently I do something like this :
edit value of set constant
The only option from the right clic menu is "empty set"... can't event insert / remove like in an array 😞
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-editing-of-map-and-set-constants/idi-p/4013327
