For projects, libraries, and their associated files, if the "Save Version" property is set to an earlier version of LabVIEW, the project and its files are not recompiled to the editor version. There should be an option on the Mass Compile dialog that allows the "Save Version" property of projects, libraries, and classes to be overridden.
