Spectre_Dave
Master Tab Page
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
Add a Master Tab Page for those controls / Indicators that need to be accessible from all Tabs.  We could designate a place - say across the top or along the Right - where all Master controls / Indicators would reside. Also a good place to put Company or project logos.  The master tab should be defaulted to Transparent to inherit the other Tab colors.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
7 Comments
JackDunaway
Trusted Enthusiast
You mean, kindof like a "Slide Master", a template for every tab? I might like this idea. Does it show up as a tab in run-mode, or does it only show up in edit mode?
This would eliminate the main reason I suggested the idea about removing shadows from floating objects (which to date has received a whopping 0 Kudos!).
Message Edited by JackDunaway (mechelecengr) on 09-11-2009 01:05 PM
Spectre_Dave
Active Participant
Exactly like a Slide MasterI see it showing up in edit as well as run modeOf course we need a property node to control this pragmatically during run mode.
CLA
parthabe
Trusted Enthusiast
"we need a property node to control this pragmatically during run mode." Dave, did you mean to say "programatically"... ?!
- Partha ( CLD until Oct 2027 🙂 )
Spectre_Dave
Active Participant
I meant Programmatically but I was seduced by the spell checker 🙂
CLA
RoyA
Why not just make your tab control a little shorter and place your Master controls above the top or below the bottom on the 'generic' FP?  They are then accessible no matter what tab you are on.
Spectre_Dave
Active Participant
That is a work around but the Master page will give a more professional apearance
CLA
Darren
Proven Zealot
Status changed to: Declined
